[GRASS-dev] [GRASS-user] importing big vector data
Markus Metz
markus.metz.giswork at gmail.com
Tue Mar 4 13:08:36 PST 2014
On Tue, Mar 4, 2014 at 8:53 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Tue, Mar 4, 2014 at 5:13 PM, Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> [I moved this discussion to grass-dev ML which seems to be more appropriate]
>> 2014-03-03 23:27 GMT+01:00 Markus Metz <markus.metz.giswork at gmail.com>:
>>>> -> after 110min failed with "ERROR: G_calloc: unable to allocate 101 *
>>>> 4 bytes of memory at allocation.c:81" (when Finding centroids for OGR
>>>> layer <buildings>...), memory peak 3.6GB
>>> This works for me on a desktop machine with quadcore AMD Phenom @ 4GHz
>>> and 16 GB RAM with Scientific Linux. Memory peak was 6.3 GB and it
>>> took 1 hour, but that included snapping which costs time and memory
>>> (my first attempt was also successful but I didn't measure processing
>>> time), and I processed at the same time a time series of climate data
>>> in a different GRASS session. There are a number of topological errors
>>> in the shapefile, amongst others there are 6619 overlapping areas
>>> which are too large to be removed by snapping and might need manual
>>> cleaning.
>>> The memory allocation errors you experienced are strange, they should
>>> not happen on a system with 48 GB RAM. Can you hack v.in.ogr and make
>>> it try to allocate e.g. 8 GB of memory right at the beginning? If that
>>> fails, you could check how much RAM is free on your system. Disk space
>>> can also be a limiting factor but seems unlikely in your case.
>> right, this strange, I used code bellow
>> int i;
>> int base = 1e6;
>> char *buf = NULL;
>> for(i = 1 ; i <= 8000; i++) {
>> G_debug(0, "%d -> %ld", i, i * base);
>> buf = G_realloc(buf, i * base);
>> if (i % 100 == 0)
>> sleep(1);
>> it fails when trying to allocate about 2GB,
> Since i and base are both int, integer overflow will occur for i *
> base > 2^31 - 1 and i * base will be converted to 1 by G_realloc().
> The second argument to G_realloc() must be of type size_t, see also
> man realloc.
> Thus, no wonder that the test fails when trying to allocate more than
> 2GB, but it does not explain why v.in.ogr fails. Did you perform a
> memory test with memtest?
>> D0/0: 2047 -> 2047000000
>> D0/0: 2048 -> 2048000000
>> Current region rows: 3, cols: 7
>> ERROR: G_realloc: unable to allocate 2048000000 bytes of memory at main.c:101
I was wrong, 2048000000 is smaller than 2^31 - 1, thus no integer overflow.
>> There is memory available and no limits per process:
Are you sure that there are no limits per process?
Markus M
>> $ free -m
>> total used free shared buffers cached
>> Mem: 48395 4587 43808 0 3272 361
>> -/+ buffers/cache: 953 47441
>> Swap: 47682 0 47682
>> Trying to investigate more. In any case thanks for testing... Martin
> I get without GRASS_VECTOR_LOWMEM a memory peak of 8.3GB and 22 min
> processing time. The conversion from non-topological vector to
> topological vector needs some time.
> With GRASS_VECTOR_LOWMEM I get a memory peak of 6.3GB. I would have
> expected a larger difference with regard to GRASS_VECTOR_LOWMEM.
> Markus M
