[GRASS-dev] [GRASS GIS] #2209: r.ros fails with -s flag with invalid descriptor error
trac at osgeo.org
Wed Mar 5 20:04:31 PST 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
Steps provided with sample fire simulation data
(http://grass.osgeo.org/download/sample-data/) fails for GRASS 7 (trunk).
When G7:r.ros is used with `-s` flag it reports `ERROR: Invalid
descriptor: somenumber`:
r.ros -s model=fuel_model moisture_1h=1hour_moisture
moisture_live=live_moisture velocity=wind_speed direction=wind_direction
slope=slope aspect=aspect elevation=elevation output=my_ros
100%
ERROR: Invalid descriptor: 11
I'm in demomapset. All output maps are created (my_ros.base, my_ros.max,
...) including `my_ros.spotdist` and I can run G7:r.spread.
It works without `-s` flag:
r.ros model=fuel_model moisture_1h=1hour_moisture
direction=wind_direction slope=slope aspect=aspect elevation=elevation
output=my_ros
It seems that the error goes from source:grass/trunk/lib/raster/close.c:
$ grep -Irn "Invalid descriptor" .
./lib/raster/close.c:74: G_fatal_error(_("Invalid descriptor: %d"),
fd);
./lib/raster/close.c:107: G_fatal_error(_("Invalid descriptor: %d"),
fd);
Rewritten from the discussion at grass-dev:
[http://lists.osgeo.org/pipermail/grass-dev/2014-January/066740.html
Testing sample fire simulation data in GRASS 7] ([http://osgeo-
org.1560.x6.nabble.com/Testing-sample-fire-simulation-data-in-
GRASS-7-td5096039.html nabble],
[http://comments.gmane.org/gmane.comp.gis.grass.devel/56048 gmane]).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2209>
