[GRASS-dev] [GRASS GIS] #1691: r.ros and r.spread don't overwrite
trac at osgeo.org
Wed Mar 5 20:26:59 PST 2014
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-releasebranch64
Keywords: r.ros, r.spread | Platform: Linux
Cpu: x86-64 |
Changes (by wenzeslaus):
* milestone: 6.4.3 => 7.0.0
Comment:
Replying to [comment:1 hamish]:
> perhaps for r.ros because output= is just a prefix for a number of
output maps?
See #2136 for the prefix/basename discussion and fix of overwrite for
G7:i.pca and G7:r.texture (r58311).
However, from the quick test, this seems to work in the current trunk
(r59190):
$ r.ros model=aaa moisture_1h=bbb moisture_live=ccc output=ddd
r.ros complete. Raster maps <ddd.base>, <ddd.max> and <ddd.maxdir>
created.
ERROR: Raster map <ddd.base> already exists in mapset <PERMANENT>
$ r.ros --overwrite model=aaa moisture_1h=bbb moisture_live=ccc output=ddd
created.
The problem now is that when I already have map named as the
prefix/basename, it will not let me proceed:
$ r.mapcalc "eee = 1"
$ r.ros --overwrite model=aaa moisture_1h=bbb moisture_live=ccc output=eee
ERROR: option <output>: <eee> exists.
This may be good for safety but then the error message (or the situation)
is confusing because when I do overwrite, it will not overwrite that
`eee`, it will create new ones (`eee.*`) and I will still have the old
`eee`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1691#comment:2>
