[GRASS-dev] Working with GRASS without starting it explicitly on windows
Glynn Clements
glynn at gclements.plus.com
Thu Mar 6 00:42:02 PST 2014
Pietro wrote:
> yes, I' attached the results
I see nothing fundamentally wrong there.
In theory, this could be a problem:
'PYTHONSTARTUP':
'C:\\Python27\\lib\\site-packages\\spyderlib\\scientific_startup.py',
Also, some of the directories which are ahead of GRASS in the PATH
setting could create issues. Try setting PATH so that it only includes
the base Windows directories plus the GRASS directories.
