[GRASS-dev] polygon boundaries not showing
    Paulo van Breugel
    p.vanbreugel at gmail.com
    Fri Mar  7 01:40:55 PST 2014
I really thought I checked that, but apparently not :-/ ... (just for
clarity, in the gui, the boundary feature type should be enabled).
But it is good if this is enabled by default (as it always has been as
far as I am aware when opening a vector layer in the GUI), thanks for
adding that back.
Cheers,
Paulo
On Fri 07 Mar 2014 10:12:00 AM CET, Martin Landa wrote:
> Hi,
> 2014-03-05 15:28 GMT+01:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
>> In GRASS 7, rev 59197 (running on Ubuntu 13.10 64bits) the polygon
>> boundaries are not showing. Or more correctly, they do show as very thin
>> whitish lines, but line width and colour cannot be changed. This is if cairo
>> is used for rendering. With png rendering, the polygons are not shown at al.
>> Line vectors do show normally.
> you need to enter `d.vect type=area,boundary`. I added 'boundary' to
> default answer in r59208.
> Martin
