[GRASS-dev] [GRASS GIS] #2212: Map display fails to display top layer if 29 or more layers are in the list
GRASS GIS trac at osgeo.org
Sun Mar 9 20:48:23 PDT 2014
list
 Reporter:  bhlevca  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  7.0.0
Component:  Default  |     Version:  svn-trunk
 Keywords:  display  |    Platform:  Linux
      Cpu:  x86-64   |
Comment(by wenzeslaus):
 I don't have exact numbers but I can confirm that I experienced something
 like that several times.
 And if you are doing some animations, make sure that you check
 G7:g.gui.animation. You can add there multiple layers (e.g. animate
 elevation raster and contours with static boundary layer at the same).
 Other links: https://www.youtube.com/watch?v=Pi1ESk9iPwk,
 http://grasswiki.osgeo.org/wiki/WxGUI_Animation_Tool
Ticket URL: <https://trac.osgeo.org/grass/ticket/2212#comment:3>
