[GRASS-dev] [GRASS GIS] #2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
trac at osgeo.org
Mon Mar 10 02:08:42 PDT 2014
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: r.in.gdal, v.in.ogr, gui | Platform: Unspecified
Cpu: Unspecified |
Comment(by mlennert):
I would like to revive this discussion. Recently, I imported a vector file
with the wxgui import wizard. I got a message that there were a series of
errors and a hint to try to set a specific snapping distance. However, in
the wizard there is no way to set the snap parameter and there is no way
to get from the wizard to the actual module. You have to be an informed
user to know that you have to launch the module from the terminal, or with
the --ui option.
Again, I plead very strongly for not dumbing down the GUI too much and for
leaving passages to power-user approaches. Even if such passages might
confuse some newbie users (although I would like to see some stats on how
often this really happens), I think that the improvement in ease of use
for other users and the pedagogical effect of showing these advanced
approaches instead of hiding them are worth the occasional confusion.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:17>
