[GRASS-dev] [GRASS GIS] #2211: g.gui.iclass raise a PyAssertionError
GRASS GIS trac at osgeo.org
Mon Mar 10 02:57:40 PDT 2014
  Reporter:  zarch        |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Display      |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  g.gui.iclass, wxPython 3
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by zarch):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:1 annakrat]:
 > I fixed it hopefully in r59207.
 Yes, now it works fine, thanks!
 > Please mention next time that you use wxPython 3, as a keyword for
 example.
 Sorry about that, you are right, I forgot to mention this important point!
 Sometime I have some warning like GRASS is using deprecating methods,
 should I report this warning somewhere, are you using wxPython3 too?
 for example at the moment if I run g.gui.iclass I got:
 G70 edi/pietro> g.gui.iclass
 /home/pietro/docdat/src/gis/grass/grass_trunk/dist.x86_64-unknown-linux-
 gnu/scripts/g.gui.iclass:101: wxPyDeprecationWarning: Using deprecated
 class PySimpleApp.
   app = wx.PySimpleApp()
 Let me know If I should report this kind of things somewhere, best regards
Ticket URL: <http://trac.osgeo.org/grass/ticket/2211#comment:2>
