[GRASS-dev] [GRASS GIS] #2214: animator fails to render a second time
GRASS GIS trac at osgeo.org
Mon Mar 10 17:01:21 PDT 2014
 Reporter:  bhlevca  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  7.0.0
Component:  wxGUI    |     Version:  unspecified
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
Comment(by annakrat):
 Are you talking about Animation Tool (command g.gui.animation)?
 Please be more specific how to reproduce the error, what does it mean
 second time?
 Replying to [comment:1 bhlevca]:
 > Replying to [ticket:2214 bhlevca]:
 > > The animator works if it is used only once. It one tries to use it a
 second time the rendering will fail.
 > Forgot to mention that GRASS needs to be closed and restarted in order
 to make the animator work again.
 I doubt that. Restarting Animation Tool should be sufficient for whatever
 error is there.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2214#comment:2>
