[GRASS-dev] [GRASS GIS] #2214: animator fails to render a second time
GRASS GIS trac at osgeo.org
Mon Mar 10 17:20:26 PDT 2014
 Reporter:  bhlevca  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  7.0.0
Component:  wxGUI    |     Version:  unspecified
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
Comment(by annakrat):
 Replying to [comment:3 bhlevca]:
 > I am using g.gui.animation from the File-> Animation tool.
 > Second time means that if I want to create another animation without
 closing the tool and the whole GRASS environment. It works if I modify the
 existing animation ( parameters, add delete maps), but if fails for
 example if I set a new region.
 when I set new region and press rerender in the animation tool, I see the
 animation in the part specified by the region. Probably you have to write
 down detailed steps of what leads to error so that I can reproduce it.
 > I tried to restart the animation tool but I get Fail rendering even if I
 start a new animation
Ticket URL: <http://trac.osgeo.org/grass/ticket/2214#comment:4>
