[GRASS-dev] [GRASS GIS] #2219: wish: all modules that create a new map should put the module call into history
trac at osgeo.org
Fri Mar 14 03:20:48 PDT 2014
history
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: history module call | Platform: All
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:4 neteler]:
> Replying to [comment:3 mlennert]:
> * vector/v.vect.stats/main.c
> * not generating a map
No, but having the command history to see which command call was used to
fill the attribute column could be useful...
> * vector/v.lrs/v.lrs.label/main.c
> * done in r59251
> * vector/v.lrs/v.lrs.create/main.c
> * done in r59252
> * vector/v.lrs/v.lrs.segment/main.c
> * done in r59253
> * vector/v.net.visibility/main.c
> * done in r59247; additionally r59248
Thanks !
> * vector/v.kcv/main.c
Agreed that it's not really useful here.
> TODO: Here is would be nice to "inject" the vector cmd history into the
> raster history function (no idea how?) in order to write it out for the
> raster output:
> * vector/v.surf.idw/main.c
> * vector/v.neighbors/main.c
> * vector/v.to.rast3/main.c
This should be the same as v.to.rast, no ?
How about the other way around: raster->vector modules ?
But again, my main issue is actually that to see that history you have to
use the -h flag for vectors, but not for rasters...
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2219#comment:5>
