[GRASS-dev] [GRASS GIS] #2220: d.vect fails to update layer list on map selection
trac at osgeo.org
Sat Mar 15 20:22:34 PDT 2014
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [ticket:2220 marisn]:
> #1605 has returned - with current trunk d.vect doesn't update vector
layer list in its gui.
This is a different issue but the same result.
> Could this be related to wxPython: 3.0.0.0 ?
Yes, it is related. What puzzles me is that when you run d.vect from
terminal, the layers are there correctly. The problem is that the layers
are not updated but I have no clue what's going on so far.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2220#comment:1>
