[GRASS-dev] [GRASS GIS] #2083: Add 3D raster (volume) support to d.legend
trac at osgeo.org
Mon Mar 24 20:56:50 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: d.legend, raster3d | Platform: All
Cpu: All |
Comment(by wenzeslaus):
New patch for G7:d.legend added. It adds new option `rast3d` to `d.legend`
and renames option `map` to `rast`. Tested with:
* `d.mon png`
* `d.mon wx0`
* g.gui (2D and 3D)
Patch breaks API (backwards compatibility), so I fixed also wxGUI and
`d.rast.leg` (which I didn't test). wxGUI 2D works the same way as before
including the case of wrong legend parameters (both dialog and legend
disappears but it is possible to show dialog by re-hiding and re-showing
legend). wxGUI 3D works also in the same way (wrong parameters cause
segmentation fault). No explicit support for 3D raster added to GUI, this
would be nice in the future.
GUI section with `rast` and `rast3d` is called `Input`, is that correct?
Please review the patch.
> d.legend --help
Description:
Displays a legend for a raster or 3D raster map.
Usage:
d.legend [-vcnsfs] [rast=name] [rast3d=name] [color=name]
[lines=value] [thin=value] [labelnum=value] [at=bottom,top,left,right]
[use=value[,value,...]] [range=min,max] [font=string] [fontscale=value]
[path=name] [charset=string] [--help] [--verbose] [--quiet]
Parameters:
rast Name of raster map
Either this option or rast3d option must be specified
rast3d Name of 3D raster map
Either this option or rast option must be specified
I did not tested new legend with other GUI tools. User documentation not
updated yet. To test basic case, use:
# generate data
r3.mapcalc "test_2 = row()"
# set some color table
r3.colors map=test_2 color=elevation
# use non-gui monitor
# try some legends
d.legend rast3d=test_2 at=10,50,10,20
d.legend rast3d=test_2 at=10,50,30,40 use=10,20,50
Question: How to get nice error message for 3D raster?
> d.legend rast=xxxx
ERROR: Raster map <xxxx> not found
> d.legend rast3d=xxxx
WARNING: Unable to open range file for [xxxx in ]
WARNING: color support for [xxxx] in mapset [] missing
ERROR: Color file for <xxxx> not available
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:5>
