[GRASS-dev] [GRASS GIS] #2230: 'g.region -p' writes new WIND file, causes race condition for parallel jobs
trac at osgeo.org
Tue Mar 25 01:11:17 PDT 2014
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Default | Version: svn-develbranch6
Keywords: g.region | Platform: Linux
Cpu: x86-64 |
In tracking down some strangeness I've just noticed that 'g.region -p' or
'g.region -g' writes out a new (unchanged) WIND file whenever it runs.
This is a problem when you have many jobs working in parallel and a bunch
of them starting at the same time all call 'eval `g.region -g`' at the
start of their scripts. About 5% of the time I'm hitting the file before
it is completely written and the unfortunate g.region G_fatal_error()s
with a missing projection parameter or similar.
one solution is to not open the WIND file for writing if just read-only
command line terms are given, another is to write to a .tmp file and move
it into place atomically.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2230>
