[GRASS-dev] [GRASS GIS] #2017: osgf compilation error (fixed?)
trac at osgeo.org
Tue Mar 25 05:29:45 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Keywords: libc, osgf, libavutil | Platform: Linux
Cpu: x86-64 |
Comment(by edleaver):
Replying to [comment:15 hamish]:
Well, I'm not a GRASS dev, but fwiw while the #include
<libavutil/mathematics.h> fix to gsd_img_mpeg.c enabled a successful build
back in January, more recently I've run into problems with ctypes
generation / python wrapping when FFMPEG was enabled, e.g. at svn revision
59324:
python -t -3 -m py_compile
/home/leaver/project/Grass/Fedora/grass7_svn/dist.x86_64-unknown-linux-
gnu/etc/python/grass/lib/vedit.py[[BR]]
Status: Processing description list.[[BR]]
Error: /usr/include/GL/gl.h:90: Syntax error at '\n'[[BR]]
Error: /usr/include/GL/gl.h:93: Syntax error at '\n'[[BR]]
...and stops (with 4% cpu usage in python process). I haven't traced the
source, but this doesn't occur when I remove --with-ffmpeg and friends
from my configuration script, and grass7_svn then successfully builds. I'm
not reporting this as a bug, only as an fyi that there may exist ffmpeg
issues beyond the include paths, should you choose to pursue them.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2017#comment:16>
