[GRASS-dev] [GRASS GIS] #1857: Correction help file r.colors
Paulo van Breugel p.vanbreugel at gmail.com
Tue Mar 25 11:38:04 PDT 2014
In the help file of r.colors in both GRASS 6.4 and 7.0 there is the line:
 "The rules color table type will cause r.colors to read color table
specifications from standard input (stdin) and will build the color table
accordingly"
In GRASS 6.4 I assume this refers to the option "rules" in the drop down
list under "type of color table". I actually don't understand the
difference between the following two options in GRASS 6.4:
color=rules
rules=-
In GRASS 7.0 the first option does not seem to exist, I don't see it in the
drop down list under "name of color table". Thus, it seems the
"color=rules" option is left out. If that is true (it would make sense to
me), the reference to this option (mentioned above) should be removed from
the help file.
Cheers,
Paulo
>  Reporter:  pvanbosgeo   |       Owner:  grass-dev at ...
>      Type:  defect       |      Status:  new
>  Priority:  normal       |   Milestone:  7.0.0
> Component:  Raster       |     Version:  svn-trunk
>  Keywords:  r.colors     |    Platform:  All
>       Cpu:  Unspecified  |
> Changes (by neteler):
>   * keywords:  => r.colors
>   * component:  Default => Raster
> Comment:
>  pvanbosgeo, anything left here to to changed? Otherwise I suggest to close
>  as "invalid".
> Ticket URL: <http://trac.osgeo.org/grass/ticket/1857#comment:2>
> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140325/45afab1f/attachment.html>
