[GRASS-dev] [GRASS GIS] #2065: grass70 not detecting latest source build of libLAS (1.7.0)
trac at osgeo.org
Tue Mar 25 13:07:17 PDT 2014
Reporter: rashadkm | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: fixed | Keywords: liblas
Platform: Linux | Cpu: All
Comment(by hamish):
Replying to [comment:4 lucadelu]:
> I think liblas version is very old, try with newer one.
It's the stock version for Debian/Stable (Wheezy) and Ubuntu 12.04 LTS &
so should reasonably be supported. ISTR Howard saying there was an old
version which would do well to be flushed out of the system. Was it 1.2 or
earlier?
If there is a fundamental reason to make 1.7 or newer required, then
REQUIREMENTS.html should note that. But I'm not sure there is & wrt this
ticket the fn in question does exist in the 1.2 header.
regards,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2065#comment:5>
