[GRASS-dev] [GRASS GIS] #645: link documentation to new GUI developments
trac at osgeo.org
Tue Mar 25 17:39:06 PDT 2014
Reporter: timmie | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: Docs | Version: svn-trunk
Keywords: wxGUI, toolboxes, menu | Platform: All
Cpu: All |
Comment(by hamish):
Replying to [comment:11 neteler]:
> Would it be possible to parse the modules.xml file via a new
> flag --menu-description which would output the related menu
> entry in HTML code?
fwiw, I'm not excited to make that part of the module parser, the GUI
structure being present shouldn't be a prerequisite of successfully
building a module. So it would have to at least fail gracefully. I guess
it needs that anyway because a number of the helper modules aren't
available from the GUI.
> Then it could be put together at compile time as already with
> header and main HTML help text.
Yes, it would be nice to just inject it after the options description but
before the g.module(description).html text as part of tools/mkhtml.py. I'd
suggest to have it export in plain but parsable text, then the html
writing code could replace ' | ' with ' → ' or whatever as needed on
the fly.
note the tools/module_synopsis.sh code needs some help since the wxgui
layout and menudata.py changed and 'python menudata.py commands' no longer
works:
#### fixme: no longer exists
MDPY="$GISBASE/etc/wxpython/gui_modules/menudata.py"
# python menudata.py commands
# python menudata.py tree
# python menudata.py strings
python "$MDPY" commands | sed -e 's/ | /|/' -e 's/[ -].*|/|/' \
| sort -u > "$TMP.menu_hierarchy"
what's the replacement script/functionality?
(here it builds up a table of the menu locations for all modules in a
first step, then instead of re-parsing the entire menu tree for each
module, which would be slow for a full build, it just looks up the module
name in the table.)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/645#comment:12>
