[GRASS-dev] [GRASS GIS] #1081: "Attribute Table Manager" not show data and v.extract doesn't work
GRASS GIS trac at osgeo.org
Wed Mar 26 08:56:58 PDT 2014
  Reporter:  zarch   |       Owner:  grass-dev@…
      Type:  defect  |      Status:  closed
  Priority:  normal  |   Milestone:  7.0.0
 Component:  Vector  |     Version:  svn-trunk
Resolution:  fixed   |    Keywords:  v.extract
  Platform:  Linux   |         Cpu:  x86-64
Changes (by neteler):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:3 zarch]:
 > Replying to [comment:1 martinl]:
 > > Replying to [ticket:1081 zarch]:
 > > > I have a big vector table (with areas) with 22604 rows and more than
 100
 > > > columns. I'm using grass-trunk 42416 on 64bit Linux system.
 > > > If I try to visualise the attributes with "Attribute Table Manager"
 grass70 doesn't
 > > > work with both case using 'dbf' and 'pg' driver.
 > > What do you mean by "doesn't work"? Any error message, or so? BTW ATM
 needs some optimalization for larger tables, it can be very slow.
 > I mean that no any attributes it's shown (I wait for 10 minuts) with
 grass64 to see the same table, I need more or less about 1 minut.
 Continued in #2124, closing here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1081#comment:4>
