[GRASS-dev] [GRASS GIS] #1713: Error at compilation error located in grass_trunk/visualization/ximgview
trac at osgeo.org
Wed Mar 26 09:31:31 PDT 2014
Reporter: pierreroudier | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Keywords: ximgview | Platform: Linux
Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:1 neteler]:
> Is this still an issue?
I believe that the underlying issue is that the AC_CONFIG_XTRA macro no
longer works reliably with modern Linux distributions.
The only modules which use X11 directly (i.e. not through wxWidgets or
OpenGL) are !r3.showdspf and ximgview. Both of these are somewhere between
"deprecated" and "obsolete".
!r3.showdspf isn't built by default, and won't compile at present as it
uses the Motif-based GLw widget, but configure (and Platform.make.in) no
longer have any support for Motif or the GLw widget. Unless someone is
actively working on porting it to e.g. wxWidgets, it should be removed.
ximgview is probably redundant due to wximgview and/or wximgview.py.
Personally, I'd suggest removing both of these. The X11 configure checks
probably need to remain for the sake of libraries which have X11 as a
dependency, as well as for the XRender surface support in the cairo
driver.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1713#comment:2>
