[GRASS-dev] [GRASS GIS] #1888: r.terraflow won't run
trac at osgeo.org
Wed Mar 26 10:54:59 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: r.terraflow, forms
Platform: Unspecified | Cpu: Unspecified
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:3 annakrat]:
> The situation is following: in r55119 no answer is required which
results in default answer infinity, then in r55484 we started to use
wx.TextCtrl instead of wx.FloatSpinCtrl. Two simple solutions exist,
either leave it as it is, or revert r55119 but instead of "infinity" use
"inf" because forms.py use a Float validator for this text field and "inf"
is a valid number. I think we could leave it as it is and close this
ticket. Objections?
no objections, so I close the ticket
Ticket URL: <http://trac.osgeo.org/grass/ticket/1888#comment:4>
