[GRASS-dev] [GRASS GIS] #2140: m.proj does not handle cs2cs failure
GRASS GIS trac at osgeo.org
Wed Mar 26 12:12:54 PDT 2014
 Reporter:  wenzeslaus          |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  7.0.0
Component:  Projections/Datums  |     Version:  svn-trunk
 Keywords:  m.proj, cs2cs       |    Platform:  All
      Cpu:  All                 |
Comment(by wenzeslaus):
 In the current version (after r59228) the tests
 echo "111 111" > test.txt
 m.proj input=test.txt proj_out="bla bla bla" proj_in="another bla bla bla"
 outputs
 Rel. 4.8.0, 6 March 2012
 <cs2cs>:
 projection initialization failure
 cause: no arguments in initialization list
 program abnormally terminated
 ERROR: Using from definition:
 which is much better than traceback but still it does not say what is the
 problem and there is the strange "ERROR: Using from definition:"
Ticket URL: <https://trac.osgeo.org/grass/ticket/2140#comment:1>
