[GRASS-dev] [GRASS GIS] #2152: cd command does not work in GUI Command console
GRASS GIS trac at osgeo.org
Wed Mar 26 13:17:19 PDT 2014
 Reporter:  wenzeslaus           |       Owner:  grass-dev@…
     Type:  enhancement          |      Status:  new
 Priority:  normal               |   Milestone:  7.0.0
Component:  wxGUI                |     Version:  6.4.3
 Keywords:  cd, command console  |    Platform:  All
      Cpu:  Unspecified          |
Changes (by wenzeslaus):
  * type:  defect => enhancement
  * milestone:  6.4.4 => 7.0.0
Comment:
 Testing `cd` command in Python outside GRASS session:
 >>> import subprocess
 >>> subprocess.call(['cd', '--help'])
   File "<stdin>", line 1, in <module>
   File "/usr/lib/python2.7/subprocess.py", line 493, in call
     return Popen(*popenargs, **kwargs).wait()
   File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
     errread, errwrite)
   File "/usr/lib/python2.7/subprocess.py", line 1249, in _execute_child
     raise child_exception
 OSError: [Errno 2] No such file or directory
 While `cp --help` works. So, using `which` to find first `cp` and then
 `cd`:
 $ which cp
 /bin/cp
 $ echo $?
 0
 $ which cd
 $ echo $?
 1
 There is really no `cd` executable. Checking `cp` and `cd` error message
 style in command line:
 $ cp aa
 cp: missing destination file operand after `aa'
 Try `cp --help' for more information.
 $ cd aa
 bash: cd: aa: No such file or directory
 `cd` is part of bash, not a separate command. So, GUI needs to implement
 its own `cd` command using Python (`os.chdir(path)`). There is a change
 working directory item in the menu, so it might be enough just to connect
 `cp some/path` to the same handler in the similar way as `d.*` commands
 are handled. Some syntax pitfalls may occur especially on MS Windows and
 with white space and non-ASCII characters.
 With the new understanding of the problem, changing to enhancement.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2152#comment:6>
