[GRASS-dev] GRASS 7: v.to.rast -d produces empty raster when used on areas
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Thu Mar 27 06:57:11 PDT 2014
Converting areas from vector to raster with the -d flag (dense lines) in GRASS 7 results in an empty raster map.
Both on Windows and Linux.
Is that because boundaries are not lines or would you consider it as a bug?
If the latter is the case, should I file a ticket?
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140327/71631028/attachment.html>
