[GRASS-dev] [GRASS GIS] #2230: 'g.region -p' writes new WIND file, causes race condition for parallel jobs
GRASS GIS trac at osgeo.org
Thu Mar 27 08:26:31 PDT 2014
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.4
Component:  Default   |     Version:  svn-develbranch6
 Keywords:  g.region  |    Platform:  Linux
      Cpu:  x86-64    |
Comment(by wenzeslaus):
 So, looking at r59383, r59386, r59387 and r59391, what is the set of
 `g.region` flags which should be used by default when scripting. If the
 region (WIND file) cannot be changed by default, why `g.region` is
 changing it? If the region (WIND file) needs to be changed by default, we
 should put a big warning to documentation about scripting (which can be
 always parallelized).
 > I think that the issue is essentially that people don't realise that
 g.region always sets the region unless -u is given.
 Again, as in previous paragraph, this is a documentation issue. This is
 not expected behavior and it is not properly documented.
 Also I don't understand why it is necessary to write the WIND file in
 `g.region` if the content was not changed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2230#comment:3>
