[GRASS-dev] [GRASS GIS] #1719: GRASS 7 Monitor command line support
trac at osgeo.org
Thu Mar 27 12:04:05 PDT 2014
Reporter: annalisapg | Owner: grass-dev@…
Type: enhancement | Status: reopened
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: d.mon, display, d.* commands, rendering
Platform: Unspecified | Cpu: Unspecified
Comment(by glynn):
Replying to [comment:27 hamish]:
> We want to use the d.* commands on a real command line without the GUI,
as is done with Xmons in earlier GRASSes. So in a separate, super light-
weight window with no toolbar or other visual clutter. Just a command line
and a viewport window. i.e. enhance something similar to ximgview or
wximgview with a right click menu for minimal interactivity.
> See comment:4 and d.mon2.py in grass7 addons for a partial hack of
making it a bit easier to achieve this.
An alternative approach is to modify D_open_driver() to allow display
commands to be "redirected". E.g. if the environment variable
GRASS_RENDER_COMMAND is set, D_open_driver() would treat its value as the
name of a program. It would execute the specified program with the
original command line (program name and arguments) as arguments, then
exit.
Such a program would typically be a "remote control" program which sends
the command line (via DDE, TCP, or whatever) to a display server (which
could be wxGUI or something simpler).
The main reason for delegating to an external command is that it avoids
enforcing a specific communication protocol, or embedding the details into
lib/display, which would be an issue for high-level protocols such as
Windows' DDE or Python's pickle format.
Display commands which are implemented as scripts using other d.* commands
would need to implement this mechanism themselves, so that the display
server "sees" the original script, not the individual d.* commands.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:28>
