[GRASS-dev] [GRASS GIS] #2235: r.param.scale crashes during compile for revision 59387 on Ubuntu 12.0.4 x64
GRASS GIS trac at osgeo.org
Thu Mar 27 13:03:13 PDT 2014
x64
  Reporter:  dnewcomb  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  7.0.0
 Component:  Raster    |     Version:  svn-trunk
Resolution:  fixed     |    Keywords:  r.param.scale
  Platform:  Linux     |         Cpu:  x86-64
Comment(by hamish):
 Replying to [comment:3 annakrat]:
 > And it didn't crash for me.
 a guess- recent versions of Debian (and thus Ubuntu) packaging rules add
 hardening flags to the compiler CFLAGS. I believe one of the results of
 this is that it forces programs to crash instead of continuing on in a
 memory-corrupted state. It also adds a number of warnings to the compile
 log when it suspects something bad could happen.
 see https://wiki.debian.org/Hardening
 You only get those flags for a self-compile if you add them manually or if
 you use the package build scripts.
 regards,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2235#comment:5>
