[GRASS-dev] [GRASS GIS] #1429: r.watershed large grids
trac at osgeo.org
Fri Mar 28 12:47:46 PDT 2014
Reporter: dnewcomb | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.watershed, Large grids | Platform: Linux
Cpu: x86-64 |
Changes (by neteler):
* keywords: Large grids => r.watershed, Large grids
* component: Default => Raster
Comment:
I tried with the current GRASS 7.svn (r59279, approximately 7.0.0beta1)
and
r.watershed worked smoothly with 9 billion pixels (77 hours, way more
pixels
than in the original report):
GRASS 7.0.svn (nc_spm_08_grass7):~ > g.region rast=elevation -p res=0.15
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 0.15
ewres: 0.15
rows: 90000
cols: 100000
cells: 9000000000
GRASS 7.0.svn (nc_spm_08_grass7):~ > time -p r.watershed
elevation=elevation \
threshold=500000 accumulation=nc_flow_accum_wsh
drainage=nc_direct_wsh \
basin=nc_wshed_label_wsh stream=nc_stream_seg_wsh \
half_basin=nc_half_basin_wsh memory=42000 -m
SECTION 1 beginning: Initiating Variables. 5 sections total.
SECTION 1a: Mark masked and NULL cells
100%
SECTION 1b: Determining Offmap Flow.
100%
SECTION 2: A* Search.
100%
SECTION 3a: Accumulating Surface Flow with MFD.
100%
SECTION 3b: Adjusting drainage directions.
SECTION 4: Watershed determination.
100%
SECTION 5: Closing Maps.
Closing stream segments map
100%
Closing basins map
100%
Closing half basins map
100%
Closing accumulation map
100%
Closing flow direction map
real 277828.64
user 59672.08
sys 4481.16
--> 77.2 hours for
rows: 90000
cols: 100000
cells: 9000000000
Peak memory usage was 10GB (checked with munin).
Special kudos to Markus Metz for making this possible.
(I suppose the ticket can be closed at this point)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1429#comment:2>
