[GRASS-dev] [GRASS GIS] #2236: REQUIREMENTS file not clear about compilation and priority
GRASS GIS trac at osgeo.org
Fri Mar 28 14:03:10 PDT 2014
 Reporter:  wenzeslaus                               |       Owner:  grass-dev@…
     Type:  task                                     |      Status:  new
 Priority:  trivial                                  |   Milestone:  7.0.0
Component:  Docs                                     |     Version:  svn-trunk
 Keywords:  compilation, requirements, dependencies  |    Platform:  Unspecified
      Cpu:  Unspecified                              |
 Th file source:grass/trunk/REQUIREMENTS.html list ''General requirements''
 and ''Optional requirements'' however, this is not as useful as it could
 be.
 For example, Python is in ''Optional requirements'' but you cannot build
 GRASS documentation and probably other things without it. Moreover,
 without Python you cannot use any module from scripts and temporal (which
 is not noted anywhere).
 And in the same ''Optional requirements'' category there is R language and
 MySQL libraries which are really optional and not critical at all.
 By the way, ''R'' is referred as just ''R'' at their website
 (http://www.r-project.org/) and other places. Description of a package in
 Ubuntu says ''GNU R'' and ''R''. The project for development of this
 software is sometimes referred as ''R project'' (note the lower p), most
 notably the URL of the web site. However, since ''R'' is too short,
 sometimes, ''R * environment'', ''R * system'' or, previously mentioned,
 ''GNU R'' are used.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2236>
