[GRASS-dev] [GRASS GIS] #2237: r.stream.basins to trunk?
trac at osgeo.org
Fri Mar 28 15:14:49 PDT 2014
Reporter: hellik | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: unspecified
Keywords: | Platform: All
Cpu: All |
summary of devML-discussion in order to avoid getting it lost for further
decisions:
http://lists.osgeo.org/pipermail/grass-dev/2014-March/067987.html
hi,
at the Vienna Code Sprint we're discussing moving the r.stream.* -modules
to
trunk.
transition most of the r.stream.* is clear, but there may be some
overlapping between r.water.outlet, r.watershed and r.stream.basins.
short comparison
- r.water.outlet [2] generates a watershed basin from a drainage direction
map and a set of coordinates representing the outlet point of watershed.
- r.stream.basins [1] is prepared to delineate basins and subbasins with
different input data.
It can delineate basins with three methods:
Using coordinates: this option simply copies functionality of
r.water.outlet.
Using vector points: it allow to manually point outlets with any
method
Using streams (most advanced): it allow on lots of modifications. See
examples for more details.
This module is prepared to delineate unrestricted number of basins in one
step.
- r.watershed [3]:
basin
Output map: Unique label for each watershed basin. Each basin will be
given a unique positive even integer. Areas along edges may not be large
enough to create an exterior watershed basin.
0 values indicate that the cell is not part of a complete
watershed basin
in the current geographic region.
as cloning/doubling functionality should be avoided, how to proceed now to
with these partly overlapping modules?
to the aim of avoiding duplicates in the core, we would like to have your
feedback about the following options:
1) to keep r.stream.basins as an add-on, demanding the delineation of
multiple subbasins from coordinates to a user´s script looping
r.water.outlet;
2) to include r.stream.basins and keep also r.water.outlet;
3) to include r.stream.basins in the core and remove r.water.outlet as
obsolete.
4) ?
regards from Vienna
Madi, Helmut
[1] http://grass.osgeo.org/grass70/manuals/addons/r.stream.basins.html
[2] http://grass.osgeo.org/grass70/manuals/r.water.outlet.html
[3] http://grass.osgeo.org/grass70/manuals/r.watershed.html
http://lists.osgeo.org/pipermail/grass-dev/2014-March/067988.html
Hi Folks,
I very much appreciate the efforts in the code sprint this week!
On Thu, Mar 27, 2014 at 8:54 AM, Helmut Kudrnovsky <hellik at web.de>
> r.water.outlet;
> obsolete.
> 4) ?
> regards from Vienna
> Madi, Helmut
If r.stream.basins can replicate the functionality of r.water.outlet, I
would prefer 3 . Some argument might be made for a conservative approach
for option 2 for version 7.0 and drop r.water.outlet in version 7.1, but
7.0 is in development status. Why not make the change now?
Doug
http://lists.osgeo.org/pipermail/grass-dev/2014-March/067989.html
> approach for option 2 for version 7.0 and drop r.water.outlet in version
> 7.1, but 7.0 is in development status. Why not make the change now?
As long as results are identical, +1. If not, this should be explored
further.
Moritz
http://lists.osgeo.org/pipermail/grass-dev/2014-March/067992.html
> further.
I reproduced the example given in the manual page (NC dataset) of
r.water.outlet using r.stream.basin:
g.region rast=elev_lid792_1m -p
r.watershed elev_lid792_1m thresh=5000 accum=accum_5K
drain=draindir_5K basin=basin_5K
r.water.outlet input=draindir_5K output=basin_A30
coord=638740.423248,220271.519225
r.stream.basins dirs=draindir_5K at testing
coors=638740.423248,220271.519225 basins=basin_rstreambasins
r.mapcalc expression="diff=basin_rstreambasins-basin_A30"
r.info diff
| Layer: diff Date: Thu Mar 27 14:34:25 2014
| Mapset: testing Login of Creator: madi
| DataBase: /home/madi/grassdata
| Title: ( diff )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 750
| Columns: 700
| Total Cells: 525000
| Projection: Lambert Conformal Conic
| N: 220750 S: 220000 Res: 1
| E: 639000 W: 638300 Res: 1
| Range of data: min = 0 max = 0
| Data Description:
| generated by r.mapcalc
| Comments:
| basin_rstreambasins - basin_A30
Best regards,
madi
for the record, all other r.stream.*-modules are already moved to grass7
trunk (http://lists.osgeo.org/pipermail/grass-dev/2014-March/068012.html)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2237>
