[GRASS-dev] [GRASS GIS] #2238: minor change in r.stream.segment syntax
trac at osgeo.org
Sat Mar 29 14:45:06 PDT 2014
Reporter: madi | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.stream.segment | Platform: Unspecified
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:1 neteler]:
> Done in r59509 (trunk) and r59510 (releasebranch_7_0).
thanks
> BTW: the param description wording is a bit odd.
> in_stm_opt = G_define_standard_option(G_OPT_R_INPUT);
> in_stm_opt->key = "stream_rast";
> in_stm_opt->description = _("Name of input streams mask raster
map");
> in_dir_opt = G_define_standard_option(G_OPT_R_INPUT);
> in_dir_opt->key = "direction";
> in_dir_opt->description = _("Name for input raster map with flow
direction");
> and should perhaps be sync'ed to that of "direction" (in all modules).
yes; any template/example around there to facilitate
unification/harmonizing not only for r.stream.* but also for other
hydrologically oriented modules?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2238#comment:2>
