[GRASS-dev] G7 GUI a bit too chatty
Vaclav Petras
wenzeslaus at gmail.com
Mon Mar 31 16:54:15 PDT 2014
Thanks for the report. Actually, there are tickets for this already.
On Mon, Mar 31, 2014 at 5:44 PM, Maciej Sieczka <msieczka at sieczka.org>wrote:
> GRASS 7.0 GUI keeps printing a bunch of non-fatal messages to the
> terminal, like these (it took me 1 minute to collect them with typical
> operations like add&query a raster layer etc.):
> GRASS 7.0.0svn (spearfish60):~/aur/grass70-svn > /opt/grass70-svn/etc/gui/
> wxpython/gui_core/goutput.py:234: wxPyDeprecationWarning: Call to
> deprecated item 'SetVirtualSizeHints'.
> self.outputSizer.SetVirtualSizeHints(self.panelOutput)
https://trac.osgeo.org/grass/ticket/2028
> (wxgui.py:5163): Gtk-CRITICAL **: IA__gtk_widget_set_size_request:
> assertion 'width >= -1' failed
> assertion 'height >= -1' failed
https://trac.osgeo.org/grass/ticket/2160
https://trac.osgeo.org/grass/ticket/2027 (similar)
> I know these are no huge problem as such. But could they be avoided at
> some low cost? They are annoying, if you use terminal.
The first is not trivial but some day it will be hopefully fixed. The
second is really annoying and it seems that it is more wxWidgets problem
but it is unclear.
Vaclav
> Maciej Sieczka
> http://www.sieczka.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140331/d3a766cf/attachment-0001.html>
