[GRASS-dev] [GRASS-SVN] r60054 - in grass/trunk: display/d.extract display/d.path display/d.vect.chart general/manage/lister lib/sites lib/vector/Vlib ps/ps.map raster/r.carve raster/r.contour raster/r.le/r.le.setup raster/r.random raster/r.stream.extract raster/r.stream.order raster/r.stream.segment raster/r.stream.snap raster/r.to.vect raster/r.volume raster/simwe/simlib vector/v.buffer vector/v.build vector/v.build.polylines vector/v.class vector/v.clean vector/v.clean/test vector/v.colors vector/v.colors.out vector/v.db.connect vector/v.db.select vector/v.delaunay vector/v.distance vector/v.drape vector/v.edit vector/v.external vector/v.extract vector/v.extrude vector/v.in.ascii vector/v.in.db vector/v.in.dwg vector/v.in.lidar vector/v.in.ogr vector/v.in.region vector/v.in.sites vector/v.kernel vector/v.label vector/v.label.sa vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where vector/v.neighbors vector/v.net.alloc vector/v.net.iso vect
Martin Landa
landa.martin at gmail.com
Sun May 4 00:58:09 PDT 2014
2014-05-03 15:49 GMT+02:00 <svn_grass at osgeo.org>:
> Author: hcho
> Date: 2014-05-03 06:49:33 -0700 (Sat, 03 May 2014)
> New Revision: 60054
I would say that such invasive changes should be discussed in advance.
Now the vector library goes in different direction that raster library
which promote fatal error even if raster map not found so the raster
modules don't check return code of Rast_open_old() at all. Even this
function has still integer return type. I am not fun of calling
G_fatal_error() on such places. But we need to keep some consistency
and to define rules when call G_fatal_error() and when G_warning() +
error return code is preferable (and then to update alll modules to
check the return code).
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
