[GRASS-dev] [GRASS GIS] #2278: G__tempfile() lacks perror support
GRASS GIS trac at osgeo.org
Sun May 4 01:31:53 PDT 2014
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  LibGIS       |     Version:  svn-releasebranch70
 Keywords:  r.hants      |    Platform:  Unspecified
      Cpu:  Unspecified  |
 (The problem arises from r.hants Addon use, reported on grass-user)
 Using r.hants (derived from r.series) on almost 600 raster
 maps generates an "ERROR: no temp files available" on
 Linux 64bit. The input maps have been registered with
 r.external:
 D2/3: G_file_name(): path = /home/user/grassdata/latlong/cloro/GDAL
 /home/user/grassdata/latlong/cloro/.tmp/localhost.localdomain/12772.6
 /home/user/grassdata/latlong/cloro/.tmp/localhost.localdomain/12772.7
 /home/user/grassdata/latlong/cloro/.tmp/localhost.localdomain/12772.8
 /home/user/grassdata/latlong/cloro/.tmp/localhost.localdomain/12772.9
 GRASS 7.1.svn (latlong_wgs84):~ >
 For a better error message, perror() should be used:
 in lib/gis/tempfile.c
 char *G__tempfile(int pid)
     do {
     int uniq = G_counter_next(&unique);
     sprintf(name, "%d.%d", pid, uniq);
     G_file_name(path, element, name, G_mapset());
     while (access(path, F_OK) == 0);
 We need to explain the error with perror() as done in
 in lib/gis/mapset.c
     if (access(mapset, F_OK) != 0) {
     perror("access");
     G_fatal_error(_("MAPSET <%s> not available"), mapset);
 Anyone able to modify the while() loop in lib/gis/tempfile.c
 accordingly?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2278>
