[GRASS-dev] [GRASS GIS] #2083: Add 3D raster (volume) support to d.legend
trac at osgeo.org
Sun May 4 23:24:46 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: d.legend, raster3d | Platform: All
Cpu: All |
Comment(by hamish):
Replying to [comment:6 wenzeslaus]:
> Please review the patch, interface and tests here and/or
> test the new functionality (you can use GUI if you want).
> I would like to apply the patch soon and not to risk that
> some changes in GUI will break it.
it's pretty good, I'll look at merging it ASAP.
> Other issue is that it is API break, since I'm replacing
> `map` by `rast`. This would be concern if this change would
> not be applied also to release branch.
it's only for grass 7 which isn't released yet, so no problem to change
the module options as long as a grep is done on scripts/, gui/, and grass-
addons/ + html docs to make sure everything else is in sync. The module
command line options for G7 are only hard frozen the day 7.0.0 ships. And
then existing options will be completely frozen for many many years...
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:7>
