[GRASS-dev] [GRASS GIS] #2083: Add 3D raster (volume) support to d.legend
trac at osgeo.org
Mon May 5 03:08:34 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: d.legend, raster3d | Platform: All
Cpu: All |
Comment(by hamish):
ok, done in trunk, try >= r60104.
I reworked most of the C code in the patch, but the python stuff was
applied verbatim.
some minor feedback/notes:
* changed enum defines to be less like official ones in include/*.h. Also
moved them into local_proto.h.
* to help code readability used TRUE and FALSE for boolean ints. (defined
in gis.h)
* no need to use {curly} brackets if the statement which follows is a
short one liner.
* if $(RASTER3DLIB) is added to the Makefile, $(RASTER3DDEP) needs to be
added too.
* still need to figure out the trick to launch the GUI when no options
are required but some option is required without asking the user to type '
--ui'.
* I added a new -c flag to `r3.stats` so that the new d.legend '-d'
histogram distribution flag will work for raster3d maps too.
please test.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:8>
