[GRASS-dev] [GRASS-SVN] r60054
Mon May 5 05:48:16 PDT 2014
Martin Landa wrote:
> 2014-05-03 15:49 GMT+02:00  <svn_grass at osgeo.org>:
> > Author: hcho
> > Date: 2014-05-03 06:49:33 -0700 (Sat, 03 May 2014)
> > New Revision: 60054
> I would say that such invasive changes should be discussed in advance.
> Now the vector library goes in different direction that raster library
The vector library has always used status returns; it's just that
almost nothing bothered to actually check them.
This patch just fixes many instances of a specific bug in one go.
Personally, I would have fixed it by eliminating status returns;
*that* would have qualified as an "invasive" change.
