[GRASS-dev] [GRASS GIS] #2278: G__tempfile() lacks perror support
trac at osgeo.org
Mon May 5 06:43:13 PDT 2014
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: LibGIS | Version: svn-releasebranch70
Keywords: r.hants | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:2 mmetz]:
> Replying to [ticket:2278 neteler]:
> > (The problem arises from r.hants Addon use, reported on grass-user)
> > Using r.hants (derived from r.series) on almost 600 raster
> > maps generates an "ERROR: no temp files available" on
> > Linux 64bit.
> r.series with the same number of input maps should fail with the same
error. r.hants has been derived from r.series, and both modules have the
-z flag (Don't keep files open) which should avoid this problem.
Sorry, the -z flag does not help here because r.hants creates a new output
map for each input map, and these need to be kept open. For 600 input
maps, the hard limit of the number of open files is usually exceeded.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2278#comment:3>
