[GRASS-dev] [GRASS GIS] #2116: r.kappa: call to r.stats fails if spaces in path
trac at osgeo.org
Mon May 5 12:41:36 PDT 2014
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.kappa, path | Platform: Unspecified
Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:5 glynn]:
> Replying to [comment:4 mlennert]:
> > I hadn't applied the patch, yet, since you suggested G_vspawn_ex(),
and I didn't find the time to look into that. Should that solution be
preferred ?
> The spawn functions are preferable (that's what r.kappa uses in 7.0), as
they avoid the shell altogether.
Backported to 6.5 in r60121 and to 6.4 in r60122. The result is identical
7.0.
Please test on Windows and close if solved.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2116#comment:6>
