[GRASS-dev] [GRASS GIS] #1048: wxgui: g.region: can't reset `rows=' nor `cols='
GRASS GIS trac at osgeo.org
Tue May 6 00:32:58 PDT 2014
 Reporter:  msieczka                 |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  normal                   |   Milestone:  6.4.4
Component:  wxGUI                    |     Version:  svn-releasebranch64
 Keywords:  g.region, v.label, --ui  |    Platform:  All
      Cpu:  All                      |
Comment(by mlennert):
 Replying to [comment:5 annakrat]:
 > How about changing the spinctrl to text field with integer validator
 (the same we did for floatspin)? In this case there is now sense in having
 the spinctrl anyway. We can use the text field only in cases when there is
 no required answer (and maybe no default answer).
 +1. Values can be so different that spin control does not really make
 sense.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1048#comment:6>
