[GRASS-dev] [GRASS GIS] #413: doxygen comments in get_row.c are wrong?
trac at osgeo.org
Tue May 6 00:46:51 PDT 2014
Reporter: karme | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.4
Component: LibGIS | Version: svn-releasebranch64
Keywords: G_get_raster_row(), doxygen | Platform: All
Cpu: All |
Comment(by mlennert):
Replying to [comment:2 glynn]:
> Replying to [ticket:413 karme]:
> > Either the code in get_row.c is wrong or the the doxygen strings.
> The doxygen strings are wrong.
> > G_get_raster_row does not return 0 if the row is outside the window.
> There's no reason for higher-level code to care about what is
essentially an implementation detail. It shouldn't matter whether the row
is all-nulls because it's outside the array or because the stored data
happens to be all-nulls.
IIUC, return values are either 1 or -1, so just erasing the line in the
comments mentioning "return 0" should be enough ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/413#comment:4>
