[GRASS-dev] [GRASS-SVN] r60048 - grass/trunk/vector/v.in.db
Markus Metz markus.metz.giswork at gmail.com
Wed May 7 11:31:53 PDT 2014
On Fri, May 2, 2014 at 11:19 PM, Huidae Cho <grass4u at gmail.com> wrote:
> OK, I did a quick search and there are 104 calls to Vect_open_new. 63 calls don't check its return value and 41 calls check. 27 of the 41 that do the check do some cleaning work before finally throwing a fatal error. Most of the cleaning work is Vect_close(already open vectors), which I don't think is really necessary before throwing a fatal error.
Yes, it is sometimes necessary to close database drivers that have
already been successfully opened, if only because of these annoying db
driver zombies staying behind on MS Windows, which might in turn be a
problem of how G_spawn_ex() is called, or in G_spawn_ex() itself. Also
GDAL and OGR like to have their opened databases properly closed,
otherwise confusing segmentation faults can occur.
Markus M
> v.convert fcloses Digin and v.surf.rst deletes left-over files. Even Vect_close returns 1. Based on these observations, I think Vect_open_new needs to return what it's returning now on failure and the 63 calls that don't check its return value have to be fixed to avoid a potential segmentation fault. I'll fix them tonight if I didn't overlook something.
> 53 files that don't check the return value:
> ./display/d.extract/main.c
> ./lib/sites/sites.c
> ./raster/r.carve/vect.c
> ./raster/r.contour/main.c
> ./raster/r.random/random.c
> ./raster/r.stream.extract/close.c
> ./raster/r.stream.order/stream_vector.c
> ./raster/r.stream.segment/stream_vector.c
> ./raster/r.stream.snap/points_io.c
> ./raster/r.to.vect/main.c
> ./raster/r.volume/main.c
> ./raster/simwe/simlib/output.c
> ./vector/v.buffer/main.c
> ./vector/v.build.polylines/main.c
> ./vector/v.build/main.c
> ./vector/v.clean/main.c
> ./vector/v.distance/main.c
> ./vector/v.drape/main.c
> ./vector/v.edit/main.c
> ./vector/v.external/main.c
> ./vector/v.extract/main.c
> ./vector/v.extrude/main.c
> ./vector/v.in.ascii/main.c
> ./vector/v.in.dwg/main.c
> ./vector/v.in.lidar/main.c
> ./vector/v.in.ogr/main.c
> ./vector/v.in.region/main.c
> ./vector/v.in.sites/main.c
> ./vector/v.kernel/main.c
> ./vector/v.lrs/v.lrs.create/main.c
> ./vector/v.lrs/v.lrs.label/main.c
> ./vector/v.lrs/v.lrs.segment/main.c
> ./vector/v.net.alloc/main.c
> ./vector/v.net.iso/main.c
> ./vector/v.net.salesman/main.c
> ./vector/v.net.steiner/main.c
> ./vector/v.overlay/main.c
> ./vector/v.parallel/main.c
> ./vector/v.patch/main.c
> ./vector/v.perturb/main.c
> ./vector/v.proj/main.c
> ./vector/v.qcount/main.c
> ./vector/v.reclass/main.c
> ./vector/v.rectify/main.c
> ./vector/v.sample/main.c
> ./vector/v.segment/main.c
> ./vector/v.select/main.c
> ./vector/v.split/main.c
> ./vector/v.surf.rst/main.c
> ./vector/v.to.points/main.c
> ./vector/v.transform/main.c
> ./vector/v.vol.rst/main.c
> ./vector/v.voronoi/main.c
> On Fri, May 2, 2014 at 1:18 PM, Huidae Cho <grass4u at gmail.com> wrote:
>> More detail.. When this happens, Map is not fully initialized and following Vect_* calls with Map can fail unexpectedly, which caused a segmentation fault in this case.
>> On Fri, May 2, 2014 at 1:15 PM, Huidae Cho <grass4u at gmail.com> wrote:
>>> Segmentation fault when you do v.in.db ... output=a at other_mapset because Vect_open_new returns -1 with a warning, not a fatal error, "unable to create new ... is not the current mapset". I didn't check why it's returning -1 instead of throwing a fatal error in this case. I believe that this warning has to be a fatal error if no modules rely on -1 return.
>>> Huidae
>>> On Fri, May 2, 2014 at 12:59 PM, Martin Landa <landa.martin at gmail.com> wrote:
>>>> Hi,
>>>> 2014-05-02 18:53 GMT+02:00  <svn_grass at osgeo.org>:
>>>> > -    Vect_open_new(&Map, outvect->answer, with_z);
>>>> > +    if (Vect_open_new(&Map, outvect->answer, with_z) == -1)
>>>> > +       exit(EXIT_FAILURE);
>>>> please provide more info where it fails. Also note that Vect_open_new
>>>> calls G_fatal_error() so the most of modules don't check return code
>>>> of this function.
>>>> Martin
>>>> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
