[GRASS-dev] how to use the WHERE ... AND ... in a python script using variables?
Helmut Kudrnovsky
hellik at web.de
Thu May 8 14:22:15 PDT 2014
hi,
given some vector with a attribute table column defined as integer/double.
task: updating the attribute table by a WHERE ... AND ... clause.
some code snippet
Python 2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)] on
win32
Type "help", "copyright", "credits" or "license" for more information.
import grass.script as grass
A = "testdbupdate" # (<- vector name)
A
testdbupdate
B = "testupdate" # (<- column name to be updated)
B
testupdate
C = "id" # (<- column name for the WHERE ... AND clause)
C
id
grass.run_command("db.execute", sql = "UPDATE %s SET %s='*'", WHERE "%s < 2"
AND "%s > 3" % (A, B, C, C))
File "<input>", line 1
< 2" AND "%s > 3" % (A, B, C, C))
SyntaxError: invalid syntax
grass.run_command("db.execute", sql = "UPDATE %s SET %s='*'", WHERE "%s<2"
AND "%s>3" % (A, B, C, C))
"%s<2" AND "%s>3" % (A, B, C, C))
AND %s>3" % (A, B, C, C))
"%s<2 AND %s>3" % (A, B, C, C))
grass.run_command("db.execute", sql = "UPDATE %s SET %s='*'", WHERE '%s<2
AND %s>3' % (A, B, C, C))
'%s<2 AND %s>3' % (A, B, C, C))
I've tried some python command variants ....
any pointers for a working command?
thanks.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/how-to-use-the-WHERE-AND-in-a-python-script-using-variables-tp5139315.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
