[GRASS-dev] Calling GRASS from outside: cannot open shared object file
Markus Neteler neteler at osgeo.org
Fri May 9 06:12:54 PDT 2014
On Fri, May 9, 2014 at 11:52 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 09/05/14 10:59, Markus Neteler wrote:
>> Hi,
>> I get it running (on Linux, winGRASS untested) when setting up the
>> LD_LIBRARY_PATH at system level:
>> su
>> echo "`grass71 --config path`/lib" > /etc/ld.so.conf.d/grass71.conf
>> ldconfig
>> exit
>> # run as normal user:
>> python python_test_ctypes.py
>> precip_annual at user1
>> /home/neteler/grassdata/nc_spm_08_grass7
>> Works.
>> The issue is that we cannot easily enforce the users to add a file in
>> /etc/ld.so.conf.d/ since it requires admin rights.
>> Suggestions?
> Doesn't this work:
> export LD_LIBRARY_PATH= export LD_LIBRARY_PATH=$(grass71 --config path)/lib
Yes this works:
also this:
export LD_LIBRARY_PATH=`grass71 --config path`/lib
nice, I could have tried that earlier :)
Now we just need similar instructions for Windows and MacOSX.
Markus
