[GRASS-dev] [GRASS GIS] #2284: Keep pressing Ctrl+C in command	line
    Huidae Cho
    grass4u at gmail.com
    Sat May 10 12:24:42 PDT 2014
Would I miss any functionalities by using prompt.sh? I mean other than
portability between OSs, does prompt.py provide other benefits? If there's
nothing to lose in Unix by falling back to prompt.sh, I'd like to bring it
into 7 and let the user choose. Maybe if the user is in Unix, there is no
reason at all to use prompt.py?
I don't know about Windows, but what benefits would this python startup
bring compared to native cmd.exe? Just wondering...
>  Reporter:  hcho         |       Owner:  grass-dev@…
>      Type:  enhancement  |      Status:  new
>  Priority:  normal       |   Milestone:  7.0.0
> Component:  Startup      |     Version:  svn-trunk
>  Keywords:               |    Platform:  Linux
>       Cpu:  x86-64       |
> Comment(by glynn):
>  Replying to [ticket:2284 hcho]:
>  > Can we fix this? Or can we opt to use the old init.sh, which I think is
>  gone now?
>  There's no reason to revert to init.sh, but we could replace prompt.py
>  with the bash version (prompt.sh) from 6.x. The prompt script is only used
>  if you're using bash as your shell, so portability isn't an issue.
>  You can disable the fancy prompt with "unset PROMPT_COMMAND".
>  The error could probably be avoided by wrapping the entire prompt.py
>  script in a try/except block, but that wouldn't help with performance.
>  Ignoring the signal wouldn't work reliably, because you'd have to import
>  the signal module first, and any signal raised during that time would
>  still result in the KeyboardInterrupt exception.
> Ticket URL: <http://trac.osgeo.org/grass/ticket/2284#comment:1>
> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140510/5227e581/attachment.html>
