[GRASS-dev] [GRASS GIS] #2284: Keep pressing Ctrl+C in command line
Huidae Cho
grass4u at gmail.com
Mon May 12 15:56:34 PDT 2014
Ok, Let me understand it. So the keyboard interrupted exception is coming
from prompt.py, not from grass.py. If I replace prompt.py with prompt.sh,
I'm out of python completely and not facing performance hit either?
I thought as long as grass.py launches bash with whatever PROMPT_COMMAND
either being prompt.py or prompt.sh, I'm inside a python process and cannot
avoid keyboard interuption exceptions and slow performance.
Huidae
On May 12, 2014 6:37 PM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Huidae Cho wrote:
> > Would I miss any functionalities by using prompt.sh?
> No.
> > I mean other than portability between OSs,
> prompt.py doesn't provide that. The only way in which the script is
> executed is by setting the bash variable PROMPT_COMMAND. If set, bash
> treats its value as a command to execute prior to displaying the
> primary prompt ($PS1).
> If you're using bash, you can use either prompt.sh or prompt.py (or
> something of your own devising, or nothing). If you aren't using bash,
> neither of those scripts are of any use to you.
> > does prompt.py provide other benefits? If there's
> > nothing to lose in Unix by falling back to prompt.sh, I'd like to bring
> it
> > into 7 and let the user choose. Maybe if the user is in Unix, there is no
> > reason at all to use prompt.py?
> I'm not sure that we need a choice. Actually, I'm not sure that we
> even need a separate script (in any language). $PROMPT_COMMAND can be
> any bash command; it doesn't have to be an external program. We could
> just insert the appropriate code as a bash function into the custom
> <mapset>/.bashrc file generated by the startup script.
> IOW, in lib/init/grass.py, replace
> f.write("PROMPT_COMMAND=\"'%s'\"\n" % os.path.join(gisbase, 'etc',
> 'prompt.py'))
> with
> f.write("""
> grass_prompt () {
> LOCATION="`g.gisenv GISDBASE`/`g.gisenv LOCATION_NAME`/`g.gisenv MAPSET`"
> if test -d "$LOCATION/grid3/G3D_MASK" && test -f "$LOCATION/cell/MASK" ;
> then
> echo [Raster and Volume MASKs present]
> elif test -f "$LOCATION/cell/MASK" ; then
> echo [Raster MASK present]
> elif test -d "$LOCATION/grid3/G3D_MASK" ; then
> echo [Volume MASK present]
> fi
> PROMPT_COMMAND=grass_prompt
> Glynn Clements <glynn at gclements.plus.com>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140512/9eab8695/attachment.html>
