[GRASS-dev] [GRASS GIS] #2290: Grass not starting
trac at osgeo.org
Wed May 14 12:32:09 PDT 2014
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-releasebranch70
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:3 dnewcomb]:
> Downloaded r60231-962 , and had same problem. Manually set grass70.py
Windows security settings to Add USERS read and read/execute rights and
GRASS 7.0 started normally. The fix appears to be setting the correct
security settings for USERS for this file upon install.
are you installing winGRASS7-standalone installer with admin rights (e.g.
right click on the standalone installer and execute as admin)?
long time ago I've added this as a needed default to the standalone
installer:
http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-
Installer.nsi.tmpl#L96
Ticket URL: <http://trac.osgeo.org/grass/ticket/2290#comment:4>
