[GRASS-dev] [GRASS GIS] #2277: graphically set up region bounds
trac at osgeo.org
Thu May 15 08:35:43 PDT 2014
Reporter: vincent | Owner: martinl
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Resolution: fixed | Keywords: region
Platform: Unspecified | Cpu: Unspecified
Comment(by martinl):
Replying to [comment:14 mlennert]:
> Just wondering: in most of my applications, I generally would want to
keep the resolution as set before, i.e. use the -a flag in the call to
g.region. Otherwise, one will generally get weird resolutions since
drawing the rectangle as a multiple of the desired resolution is a bit
difficult.
Do you suggest to use this flag by default?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2277#comment:15>
