[GRASS-dev] [GRASS GIS] #2277: graphically set up region bounds
GRASS GIS trac at osgeo.org
Thu May 15 08:44:51 PDT 2014
  Reporter:  vincent      |       Owner:  martinl
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:  fixed        |    Keywords:  region
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by mlennert):
 Replying to [comment:15 martinl]:
 > Replying to [comment:14 mlennert]:
 > > Just wondering: in most of my applications, I generally would want to
 keep the resolution as set before, i.e. use the -a flag in the call to
 g.region. Otherwise, one will generally get weird resolutions since
 drawing the rectangle as a multiple of the desired resolution is a bit
 difficult.
 > Do you suggest to use this flag by default?
 Yes.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2277#comment:17>
