[GRASS-dev] GRASS created geotiff do not properly load into PostGIS (raster2pgsql)
Rémi Cura remi.cura at gmail.com
Fri May 16 05:15:05 PDT 2014
OK gdal is out of the way.
Like you I had troubles with the 'nan' value ,
because 'nan' is actually platform dependent AND it get casted differently
depending on the precision of the type.
Like you said the only way to get it working was manually assign a number
instead of Nan :-(
Cheers,
Rémi-C
2014-05-16 11:40 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
>  Hi,
> And thanks for the swift response!
> My GDAL version is:
> GDAL 1.11.0, released 2014/04/16.
> I recompiled GDAL recently (but not PostGIS). Can that be the source of
> error?
> However, ASCII and Tiffs with assigned NoData work…
> Cheers
> Stefan
> *From:* Rémi Cura [mailto:remi.cura at gmail.com]
> *Sent:* 16. mai 2014 11:24
> *To:* Blumentrath, Stefan
> *Cc:* GRASS developers list (grass-dev at lists.osgeo.org);
> postgis-devel at lists.osgeo.org
> *Subject:* Re: [GRASS-dev] GRASS created geotiff do not properly load
> Hey,
> what is your version of gdal (type `gdalinfo --version`)
> Cheers,
> Rémi-C
> 2014-05-16 11:14 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no
> Hi,
> And sorry for posting on two lists. Just don`t know where the issue
> belongs to…
> I tried to load a set of raster maps in Geotiff format, which I created in
> GRASS using r.external.out, into PostGIS 2.1.2dev.
> In PostGIS the raster datasets only contain NoData values, while gdalinfo
> –stats produces reasonable statistics for the respective GeoTiffs.
> I did some trouble shooting and found that the problem was that GRASS did
> not assign a numerical NoData value to the GeoTiff, but “nan”.
> When I gdal_translate same GeoTiff with –a_nodata -9999, raster2pgsql
> loads the resulting file just fine.
> Is raster2pgsql supposed to read rasters with nan as NoData values (using
> –N -9999 in raster2pgsql had no effect btw.) or should GRASS
> (r.external.out) assign a NoData value to the produced raster datasets?
> Many thanks in advance,
> Stefan
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140516/201685d5/attachment.html>
